tranny troubles
tmacsbronco
oklahoma
i have a 92 Bronco with the E40D tranny and when i shift into Drive it sits for a few seconds then kicks in. is there anything i can do to fix that and the rough shifting overall?
33038[/snapback]
basic checks are: check fluid level and condition, pull codes, check vehicle speed sensor (VSS, or also called ABS sensor) on rear diff (Code 452), check Throttle Position Sensor (TPS)
codes - EEC-IV Troubleshooting for 88-95 by Steve via Havack (Ben P) at broncodata.com http://www.broncodata.com/tech/codes.htm
check vehicle speed sensor (VSS, or also called ABS sensor) on rear diff; see here for location pic http://www.supermotors.org/clubs/superford...s=27536#content
Vehicle Speed Sensor (VSS) pic & Operational Description & Parameters (click on Sensors) by Ryan M (Fireguy50) at fordfuelinjection.com - see
http://fordfuelinjection.com/index.php?p=33
info from the VSS feeds into PCM to determine shift points
tone ring in the 8.8 or your VSS may need cleaning - as Steve once wrote; "...pull it out, wipe off any metal filings, & put it back in. No need to change it, or dump the oil unless it's LOADED with filings..."
Tone Ring location pic in 8.8 by Steve;
http://www.supermotors.org/vehicles/regist...ia.php?id=74192
Throttle Position Sensor (TPS) Test on a 92 by Richard C (Bigric, Money Pit) at SuperFord.org
http://www.supermotors.org/clubs/superford...a.php?id=118940
also see this TSB (if bronco was in water or subject to water spray under vehicle)http://home.comcast.net/~miesk5/technical_service_bulletins.htm#Water%20Intrusion%20of%20MLP/TR%20Sensor%20TSB%2095-2-12%20by%20Ford%20for%2089-94
Ford644
