tranny questions e4od
blkstang2002
i have a 1996 ford bronco with the e40d tranny and was just curious if any manufactures make a heavy duty tranny rebuild kit or anything? i was just asking cause when i decide to get the tranny rebuilt, i want it very strong. plus im adding other power adders and want no problems.
Leadsled
Bullhead City AZ(right on the river!!)
when you have it rebuilt tell the guy to install all of the updates for the e4od. without those updates that tranny is kinda weak. i burnt up 2 of them while 4x4ing out here in the desert.
blkstang2002
cool, thanks leadsled! i need all the info i need on broncos.
blkstang2002
Besides the information that you get here... you may consider giving Bauman engineering a call and try picking their brains.http://www.becontrols.com/
Good luck with the rebuild/upgrade.
joe
cool! checked it out. thanks alot! i just dont know much about their products. so do they sell parts that make the tranny very heavy duty? i dont know what to look for...lol
Baumann is a long-time well respected tranny parts company.
You are interested mostly in their E4OD Hard Parts Update Kit;
"The E4OD hard parts update kit contains all the necessary geartrain parts to update your 1996 and earlier E4OD to 1997 specifications. The kit includes: 6 Pinion Forward and 4 Pinion Overdrive Steel Planetary Carriers, Input Shaft, Center Support Shaft, Center Support Hub with Bearing, Forward ****** Bearing, Cup Plug, and Hub Gasket.Catalog Number: E4ODUPD for 1989 to 1996 E4OD $350.00"
btw, there were many E4OD upgrades by Ford over the years; I have most of them shown in my Bronco links site (see hot link below) as TSBs; I still need to add more that I have in my PC.
Those for 96 include;
developed by the MIESK5 Family and is not affiliated with the Ford Motor Company in any manner.
Diagnostic Trouble Codes And Repair Procedures; EEC-V (OBD II)
Engine Stall During Transmission Engagement TSB 97-24-23 96 Bronco
Filter, In-Line TSB 00-23-10 by Ford for 89-96 Bronco & F Series, etc.
Fluid Usage Charts TSB 01-15-07 for 80-96
New Design Elastomeric-Type Gasket for the Bottom PanTSB 96-3-22 by Ford for 96
New Design Overdrive Clutch Piston Assembly for some 96-97 TSB 96-21-15 by Ford for Vehicles Built from 12/5/95 - 6/15/96
Reverse Clutch Piston And Piston Seal Usage Service Tip TSB 96-7-28 by Ford for 96
Revised Design Forward Planet ****** Washer Service Tip TSB 96-24-18 by Ford for 96
Transmission Control Indicator Lamp (TCIL) Flashing Diagnostic Trouble Codes 62, 628 and/or 1728 & transmission shifts hard TSB 98-4-19 for 90-96
Unique Overdrive Ring Gears, One-way Clutch Retaining Ring & Center Shaft Retaining Ring Service Tip TSB 96-21-17 by Ford for 96
and to add to my site;
97-22-17 93-96 Clutch ***** Cylinder, revised
96-7-28 The reverse clutch has changed for the 1996 model
96-3-22 ELASTOMERIC GASKETS FOR MAIN CONTROL COVER AND BOTTOM PAN
also;
B&M Shift Improver Installation in a 93 Source: by Froggmann
