Tracarm bar mount
flmed
Florida
My neighbor asked me to fix his 78 bronco's tracbar, but it's missing the stock mount all together. Can anyone snap a pic of where it mounts at on the frame??
79highrider
Frenchtown NJ
I don't have a picture but it mounts to the bottum of the front shock tower on the drivers side, the front part of the tower drops a little lower, and thats where it bolts to, my bronco is not at my house atm so I can't get a picture and im going off of memory but I hope this helps
79fordguy
it mounts right behind the steering box with 2 bolts going through the frame. if the bronco had the quad front shock option it was the bottom of the shock mount in the same location. if you cant find a factory one just make it at the height down off the frame where the trac bar is parrallel with the drag lnk. when these trucks are lifted that mount needs to be changed anyway to keep sterrring geometry correct.
drubbz
