timing on an 89, 302
bart6180
elyria,ohio
i gotta play with the timing on my truck, is there anything i need to unplug so the computer dosen't keep advancing the timing while i'm doing it???
Yes, disconnect SPOUT connector & watch your fingers while timing.
your SPOUT connector is in front of distr. as Jem shows in this pic, via Steve:
http://www.supermotors.org/clubs/superford...a.php?id=249507
also:
go to this on-line ref manual for other info incl. general
http://aarc.epnet.com/application/8828/882...RVICE___REF.htm
Click:
ENGINE ELECTRICAL
GENERAL INFORMATION
ELECTRONIC DISTRIBUTOR IGNITION SYSTEM
NOTE: All fuel injected engines use the TFI-IV system. All carbureted engines use the Dura Spark II system
& read what Ryan advises here:
Timing, Ford EFI Engines by Ryan M (Fireguy50) at fordfuelinjection.com
http://fordfuelinjection.com/index.php?p=71
btw, his diagram shows SPOUT location for later years
Ford644
