yo RR,
funny stuff!
Check Engine Light (CEL) comes on when the electronic engine control system is not working properly. The check engine warning indicator comes on briefly when the ignition switch lock cylinder is turned to ON, and should turn off when the engine starts. If the check engine warning indicator does not come on when the ignition switch lock cylinder is turned to ON or if it comes on while the vehicle is moving, the system is malfunctioning
If the CEL does not light up at all when starting it; then suspect that is burnt out, loose in socket, or someone removed it. Wouldn't be the 1st time a previous owner mangled or manipulated somethAng, huh?
re your; "noticed fluid at my booster/master cylinder"
This could be a fire hazard if it is the speed control deactivation switch; it may overheat, smoke, or burn & this condition could lead to a fire.
Fires have occurred while the vehicles were parked with the ignition 'off.' as an interim repair, owners will be instructed to return their vehicles to their dealers to have the speed control deactivation switch disconnected. As soon as replacement parts are available (early April 2005), owners will be instructed to return to the dealers for installation of a new switch free of charge. Owners may contact ford at 1-800-392-3673. (note: also see recalls 05v388 and 06v286) Ford recall no. 05s28. Customers may also contact the National Highway Traffic Safety Administration's vehicle safety hotline at 1-888-327-4236 (TTY 1-800-424-9153), OR GO TO
HTTP://WWW.SAFERCAR.GOV
Source: by National Highway Traffic Safety Administration nhtsa.dot.gov
since the recall was issued, Ford has done more work on this issue.
Recall Update; Field Service Action 05S28 Speed Control System Modification Supplement #7 for 93-96 Bronco, 94-02 F-150/250 (Under 8500 GVW), 97- 02 Expedition, 98-02 Navigator, 02 Blackwood
see the tie straps?
Is this what you have now?
Recall; Fused Jumper Harness (14A411) pic; "List price on this is ~$11 (as of the date I posted the pic), but it will be installed at NO CHARGE (parts or labor) on vehicles covered by the recall. Even though the label is wrong about the fuse being internal, it should still NEVER be replaced. If it blows, it means the brake pressure switch is leaking, and (as the label states) should be replaced with the new Speed Control Deactivation Switch & adapter harness kit, listing for ~$20 right now..."
Source: by Steve
Here is the Anti-Theft Protection System Service Tips TSB 94-25-05 for 93-94 Bronco, F Series, Explorer, Ranger, Econoline & many others most significant is;
1994 F-SERIES/BRONCO - INADVERTENT ACTIVATION OF THE ANTI-THEFT SYSTEM
ISSUE Water intrusion into the Right or Left Front Courtesy Lamp Switch (refer to EVTM) of the Anti-Theft System may cause inadvertent activation of the system.
ACTION To correct this condition you should:
Remove the switch from the door.
Place a small amount of silicone sealant on the back of the connector where the wires exit the connector (enough sealant should be used to seal the connector and prevent further water intrusion).
Tape wrap the connector and about 1.5" (38mm) of the wires beyond the switch connector.
Reinstall the switch.
Verify the repair.
Wiring Diagram in a 94 from EVTM; Click Next for more Source: by Mikey350
