If you don't have an aux. tank, then it probably has 2 lines coming from the gas tank or 2 from the charcoal cannister. It is a "sealed unit" that you can't actually get into, so essentially, you can't open it up. Theoretically, what it does, is it takes the vapors from a full tank, runs them through the plastic jug behind the drivers seat, they (the vapors) go down to the charcoal cannister where the get filtered through the charcoal. In otherwords, it is a gas tank vent. I clipped the lines at the plastic vapor jug and capped the lines. It gets quite a bit of breathing through the regular filler neck and overflow hose and really isn't necessary. Just an emissions deal, that if you have emmissions there in Canada, you better leave it on. If you don't, ditch it if it is bothering you.
