yo Rangers41,
As CC advised;
and
Removal w/Tool List, & Security Torx® bolt replacement w/Metric sized bolts (5 8x70mm 1.5 Pitch Metric Bolts & 12 8x45mm 1.5 Pitch Metric Bolts) 92 - 96
Source: by Froggmann (Ken P) at
http://www.froggmann.com/Bronco/Tech/Topremoval.htm
NOTE: When removing panels retained by pushpins, use Rotunda Windshield and Moulding/Trim Removal Kit 107-R0401 or equivalent to carefully pry trim panel from inner panel. Replace any bent, damaged or missing pushpins.
Refer to the following illustration for removal and installation of trim panels.
Item Part Number Description
1 517C04 Roof Trim Rear Moulding
2 29004 Quarter Window Garnish Lower Front Moulding
3 N8071545-SW Pushpin (6 Req'd Each Side)
4 N807372-S Pushpin, Nylon (2 Req'd Each Side)
5 29010 Quarter Rear Window Garnish Rear Moulding
6 29126 Body Side Window Garnish Moulding Front Bracket
7 N800486-S9 Bolt and Washer
8 N801157-S58 ***** and Washer (2 Req'd Each Side, 1 Req'd Center)
9 518B34 Roof Trim Rear Moulding Joint Cover
10 29070 Body Side Window Garnish Moulding Bracket
as for the plastic tabs (pushpins, Trim Panel Retainer) that hold the trim on; I use an old fork; replacements in proper color (old ones are prob UV faded) can be bought @ Ford parts dealers or black one in HELP section and other sources, can be dyed w/SEM
Vinyl dye mixed @ local auto body shop paint/supply store.
Trim Panel Retainers, Interior, Plastic, pics & Ford part number N808658-SSD (Mocha Tan) in a 95
Source: by fearxfour (fourxfour95) at
http://www.supermotors.net/registry/10192/31776
Trim Panel Retainer, Interior, Plastic in 92-96 (Xmas Tree, Dorman part #700-771 pic
Source: by Dorman
http://www.dormanproducts.com/catalog/hardware2006/397-402_Sec20_Part4.pdf
Trim Panel Retainer, Interior, Plastic in 92-96 (Xmas Tree, part # N19374) (New URL as of JUN 2010) Bottom Head Diameter: 19/32" - Stem Diameter: 9/32" - Stem Length: 27/32"
Source: by northlandfasteners.com
http://shop.northlandfasteners.com/N19374-Trim-Panel-Retainer-N19374.htm;jsessionid=7B7DAA040FC24851FB3C92DE5104546F.qscstrfrnt03
For a Lift, one man
Source: by Mark C at
http://www.icehouse.net/mchristy/remtop.html
More Camper Top Links in my site @
http://www.broncolinks.com/index.php?index=474
