Stripper!
buckinbronk
When I bought my bronco the owner before me painted over the chrome on the grille and headlight assemble and I was wondering if what I could use to get it off. Would a regular paint stripper work without harming the chrome, or is there something else i could use?
Shadow_D
Schenectady, NY
Do you mean the long panel on the tailgate?
If that is what you are talking about, it is brushed stainless so you should be able to strip the paint without harming the finish, just test in an area that will not be seen by others. You will need to clean it and repolish it when you are done.
Now for the bad news. You need to sand chrome to give it a rough surface so the paint will stick to it. Assuming the last owner did it right, the chrome will never shine the way it should.
You will be better off replacing the chrome around the headlights if you want the chrome to look right.
Did he paint it black or a different color? If it is a different color you might want to repaint it black as that was a standard color for the trim.
buckinbronk
This is all on the front of the bronco. The paint on the grille is chipping and I can see the crome underneath, and it doesnt look like he sanded the chrome before he painted.
I can't believe that someone would paint the grill and headlight shrouds unless they were in bad shape to start with. However, I also believe that they are plastic and stripper will probably eat them up :( /emoticons/sad@2x.png 2x" width="20" height="20" /> .
New grill and shrouds are available from Jeff's Bronco graveyard, see the 80 and up catalog pg 72 :lol: . I would just replace the ones you have.
Windchaser
Topeka, KS
I thing that the chrome is not really chrome but kind of like a sticker. Not real chrome but more of a decal...At least my peals off like it is. I agree with the others, I would just buy another set from Jeff's, Bronco Hut, or go to a junkyard and look for a Bronco that was totalled from the rear (good luck). Have some fun.
G
Guest
Guest
Lots of people checking this topic :p /emoticons/tongue@2x.png 2x" width="20" height="20" />
BigRedTruck
ooops , That 'Guest' post was really me..I forgot to log in...
You know..I just got so excited.. :D /emoticons/biggrin@2x.png 2x" width="20" height="20" />
buckinbronk
well i sanded it all down and I am goin to be putting on a dark grey. I hope it looks allright. [-o<
88pimpin
Postwhore, Pimpin Ain't Easy
Bozeman, MT
Well, if it's a sticker, you can get that rocker panel sticker stuff from O-O-O-O'Reilly's for $20. But it may be cheaper to buy new. You could also get a billet grill for around $75 shipped on eBay. Just don't bid one the used one I'm bidding on. You could probably also get clear corners, unless the chrome part doesn't come with them. About $55 for them, shipped.
I painted my grill with Dupli-Color wheel paint. I didn't like it at first, but I like it better now.
figjeti
