2NDTOUR89
What do you all do with your stuff when you take the top off? I am sure most of you are like me and keep tools and stuff in your ride most of the time, but what keeps your stuff safe when you are *******?
i put all my bolts, fasteners, push pins, etc. in ziplock freezer bags and label them. i lay my interior trim pieces on top of the topper along with the ziplocks. that way i can't misplace anything when i put it back on because it's all together.What do you all do with your stuff when you take the top off? I am sure most of you are like me and keep tools and stuff in your ride most of the time, but what keeps your stuff safe when you are *******?
I had that same question cause i take a tool kit, straps, high lift, towels and extra cloths (in case i get really wet), ect... so i decided to build a box of my own in the back. I just used 1/2" plywood and 1x4s... i added a few hinges and a lock. it is about 54"longx20"deepx24"tall(rough guesstimate). it fits in the back without being so tall that it sticks out (about flush with the top of the rear quarters). i plan on bolting down so it doesn't go anywhere while wheeling. not that it really goes far now cause its a bit heavy when full. i have just enough room to reach in and open the tailgate. if the box does happen to move it isn't to hard to tilt it a bit to open the rear tailgate. I also am going to use a silicone caulk and some weatherproof strip to make it water tight so i can leave the top of permanently.What do you all do with your stuff when you take the top off? I am sure most of you are like me and keep tools and stuff in your ride most of the time, but what keeps your stuff safe when you are *******?
Turn my shock sensing alarm on and if anyone even tries to climb in the back, the horn goes off like a bitchWhat do you all do with your stuff when you take the top off? I am sure most of you are like me and keep tools and stuff in your ride most of the time, but what keeps your stuff safe when you are *******?
