There is no wiring harness for them...Also I ran into a problem on mine,I could be wrong but by looking at the wiring diagram in the manual and my own problem it seems the power for the radio somehow runs through the headlamp switch,something to do with the orginal dimmer,What kept happening to me was every time I cranked it up it would start to shut off and on over and over until I lowered it.At the same time I was burning up headlamp switches.But that may have been because Its not supossed to be the power wire,But it looks like the manual says it is.Thats how I found out about the wiring..So what I did was went right to the radio fuse and plugged into that AFTER the fuse so it still works like stock.And for the radios constant power wire which should be yellow? I tapped into my cig lighter wire,Havent hand any problems at all any more,,,Hope this helps,,,Mike
