single to dual inlet vs. dual to dual inlet plumbing
B-Co Kid
87 B-Co; Holley 570; Mechanical fuel pump; C6 Trans; No EEC from factory.
Coming from the fuel pressure regulator to the carb, is there any advantage/disadvantage to running a dual line to dual inlets on the carb vs. single line to dual inlets on the carb(see photo)
Yo B,
As far as I know, none that would justify that other than if lines would avoid heat by not running over top of intake manifold.
Some claim benefit of using two is more fuel volume & flow when needed  for "high performance" carbs.
However, using two adds to possibility of fuel leaks at carb inlet & filters ( if using two).
eholt80
