Saginaw p/s pump bracket
Jeff Ogden
Dayton Ohio
I have a 88 and grabbed the saginaw pump and bracket off a late 80s van but it has a different mounting for the a/c compressor so what year of van has the same mounting bracket as my 88 or do I need to go back and grab the a/c compresor that came with the brackets I got.
muddrivermike
Texas Arp
J
Jeff Ogden
Dayton Ohio
I was at O reillys last night and that pump showed up on the computer but knew nothing about it,if it will bolt up I will get it since mine is leaking. Will my existing hoses work with this pump?.
If you get the setup from the same year and engine E-series van It will be a drop in. You need to take the bracket, pump, any spacers, and High pressure hose from the van. Miesk5 has a part number for a Saginaw that has the same bolt pattern as the pump that is in your truck now.
J
Jeff Ogden
Dayton Ohio
The van must not be the same year but thinking about getting the a/c compressor off the donor so I wont have to look for another set.
79brnco
