Sad day
BigGreenBronco
North Florida
Well guys its a sad day for the bronco on the way home from college I noticed the oil pressure was dropping pulled over and she started smoking long story short motor is shot as it seems it slung a rod it was a remanufactured motor so I have a warrenty good time to drop a 351 though haha
Elmo
Forsyth Georgia
collect on the warranty first that will give you a fresh 302 to sell or trade for a 351. Have you thought about 460/ZF combo ? just a thought
Too bad man!
Ever consider a Ford Re-man engine?
Remanufactured Transmissions & Engines - Motorcraft® Brand, Broncos & all Ford vehicles
Source: by fordinstallersupport.com @ http://www.fordinstallersupport.com/files/catalogs/ptm200.pdf
get some estimates from the; Distributors (listed in each Catalog above) & Ford;
Ford has a good guarantee and the Qual is up there. And the Ford reman trannys/engines do not need to be installed by a Ford Dealer
Look at this Excerpt;
"...Ford and Motorcraft Remanufactured Transmissions and Gas Engines
Ford Motor Company, The American Road, Dearborn, MI 48121 (“Ford”) provides the following Limited Warranty on Ford and Motorcraft Remanufactured
Transmissions and Gas Engines to Ford, Lincoln and Mercury Dealers (each being a “Dealer”) or general Installers (each being an “Installer”). This Limited Warranty provides that Ford will credit the Dealer or Installer for repairing or replacing, at Ford’s option, any Ford or Motorcraft Remanufactured Transmission or Gas Engine sold by Ford that is found to be defective in factory-supplied material or workmanship subject to the following terms, conditions and limitations:
Retail Customers: To obtain warranty service, please return your vehicle to any Ford, Lincoln or Mercury Dealership or return to the Installer who
originally installed the Ford or Motorcraft Engine or Transmission Assembly in your vehicle. Please have your original dated receipt for installation date verification.
Complete Gas Engine Long Block Assemblies (6006/6V012) and Transmission Assemblies (7000/7V000/7003)
• 36 months or 36,000 miles from warranty start date, whichever occurs first. Ford will cover 100% of all parts and labor at approved warranty reimbursement rates
• If installed by a Dealer, reasonable towing charges (up to 35 miles or to the nearest Dealer) are covered only if the vehicle is not covered under
another towing insurance coverage Short Blocks (6009/6V009), Cylinder Heads (6049/6V049) and Crankshaft Kits (6303/6V303) for Gas Engines
• 12 months or 12,000 miles from warranty start date, whichever occurs first. Ford will cover 100% of all parts and labor at approved warranty reimbursement rates
Warranty Start Date
• Ford and Motorcraft Remanufactured Transmissions and Gas Engines installed by the Dealer or Installer—warranty begins on the date of installation
• Ford and Motorcraft Remanufactured Transmissions and Gas Engines sold by Dealer or Installer over-the-counter or to a retail purchaser—
on the date of sale
Limitations to the Warranty
The following limitation applies to the products covered by this Limited Warranty
• Towing charges are not reimbursable for Ford and Motorcraft Remanufactured Transmissions and Gas Engines sold
over-the-counter by a Dealer or Installer..."
read more incl the;
"No-Risk" Core Return policy means accurate quotes for engine and transmissions are no problem. 100 percent core credit will be given (regardless of damage or quality of returned core); just follow these guidelines and the return runs
smoothly.
• Returned core is the same part as the assembly purchased
• Core is 100% complete with all parts attached and all fluids drained and is returned in original package..."
Halli wrote on 30 DEC 2010 that
For a Ford Reman 5.8 long block it is 2308.00 exchange.
2210.00 for a 5.0
These are Ford dealer prices in the Mid-South
Reman 5.0 = $1914.56
GL!
BigGreenBronco
North Florida
Thanks guys! and thanxs meisk for the info i will look into that. My idea is to get a 96 351w with the roller block upgrade the cam and heads in that and get a hypertech chip. Those with the 4.56 gears i aldready have should make a beast. My question is I know i can use my old harness for a 95 351, but what about a 96 351w?
digs
