rusted headers
90bronco86
deltona Florida
Ive got a pair of headman long tube headers that i got from a friend and they are solid but they have quite a bit of surface rust and i was wondering if i could sand blast them with a low pressure sand blaster to get the rust off so i can paint them, any sugestions or help would be greatly appreciated.
yo 90,
you can have it blasted
Gacknar used "Right Stuff" rust remover
let it soak in for a few hours
hit it with a tooth brush, and then let it soak some more, rinse and repeat until all the rust is gone.
make sure that it dries 110%
Then I painted it with POR-20
Restoration pics by Gacknar (The Mall-Crawler, Jeremy, "Big grey megga beast") at http://www.supermotors.net/registry/4103/28096
brad6920
Magalia, CA
And when you go to put them on, make sure you soak the bolts with Liquid Wrench, WD-40 or some kind of penetrating oil so you have less of a chance of breaking the bolts off inside the head. Peronally, I busted 3.
Good luck.
felixrican86
