yo, Check ground cables around & on battery (incl the small gauge wire to inner fender)
Scan Tool Won’t Initiate Self-Test Due to Poor Grounds, Corroded Wiring, etc
by
Jeremy
NO CODES Troubleshooting by Ryan M (Fireguy50) at
http://oldfuelinjection.com/?p=44
excerpts;
Check Battery voltage, must be above 10.5 volts.
•Replace battery if not.
•Check battery connections, corrosion, ground faults, and wiring.
• Fix all wiring.
•Check alternator output, must be between 13.5 and 14.5 volts.
•Replace Alternator if not.
•Any recent voltage irregularities from electrical charging system can cause failures.
Check EEC relay, must show battery voltage when engaged.
•Replace relay and damaged wiring if not.
•Make sure pin 30 on the computer is hooked up correctly.
•Manual transmission computers need to sense SIG-RTN on pin 30 when in neutral.
•Automatic transmission computers need to sense Ground on pin 30 when in neutral.
READ MORE
to help go thru the steps;
Here is Ryans EEC IV PIN LEGEND
http://oldfuelinjection.com/truckpinouts.html
& EEC IV Connector Pin Outs
http://oldfuelinjection.com/?p=3
