rim width and tire width
hammer down bronco
pa.
Im 16 and just got my bronco i would like to put a 5.5in lift on it with 35s but not sure if i could put some 35x12.50x15s on my stock 8 inch wide rims if any body has done this or not im just looking for an oppinion on if its a good idea or not thanks,steve
POTTER
Connecticut
info on the truck would help...and I don't think that the stock wheels are 8inch, I beleive 7.5". You will find that tire mfg's suggest no more than 4 inches difference in tire to rim widith...so a 12.50 should be run on an 8.5 inch rim (at least) and better on a 10-10.5 inch. Now...this is the recommendation...you will find many people running 12.50's on the stockers...I just researched for a while and picked up a set of wheels myself...however, I got a set of 33x10.50's so I would not have any rubbing issues as mine is still sitting on stock suspension height. I would not go bigger than 33x12.50 on the stockers if I were you though...maybe just look for some cheap steal wheels until you can upgrade to something better...get a set of 10 inch wheels to run the 35x12.50's....just my 2 cents.
H
hammer down bronco
pa.
ok thank you. by the way my truck is a 94 with no lift for the time being. its got a 351w and the chrome wheels not the steel ones. but i dont think they made 7.5s in the chrome ones only 8 and 10s
Krafty
Ontario Canada
Okay this is from word of mouth from a group of mechanics and mudders. as long as there isn't a huge difference in the width of the tire and the rim then it will fit. they say up to 12.5 will fit on 7.5" rim it will only **** in the sidewalls at the rim making the tire taller. anything bigger then 12.5 then you need to go up to a 10" rim. I run 12.5's on 8" rims with absolutely no issues.
33x12.5x 15's are what I had before I put my lift in they ran with no issues. you can run 35's with no lift but no promises a 2" lift would be ideal and the 12.5 will fit on the stock rim
Krafty
Ontario Canada
well then you guys with the newer broncos got shafted out of tire clearance somewhere
Armed Bronco
magnum myer
Auburn, CA
My unlifted '96 has 33s. I had to trim the front bumper. It will rub a little when on very uneven ground. 35s would rub at the front of the front fender.
