redneck solution to my starter problem
wolf83
Lubbock, TX
like i said in my last post regarding my starter problem, i suspected the holes on the starter that are used to mount it to the bell housing are too large, giving the starter a little bit of slack, even when fully tightened.
so here is my redneck solution. i attached some zip ties to fill the gap in the holes. it starts up every time now. next chance i get, i will go to town and look for a sleeve of some sort to put in these holes. at least now i know what was wrong.
see pics.
W.
American Thunder
Upstate New York
The ties havent just filled in the holes, they've also provided a shim that positions the starter further from the transmission. In effect, shortening the snout of the starter. If it works better now than it did before, I would double check to make sure it's the correct starter for the truck.
wolf83
wolf83
Lubbock, TX
i thought of that too... but before i put the zip ties on, i took the starter to autozone and compared mine to the recommended model they had in stock. the 2 were exactly identical.
keep in mind that the zip ties only add 1/8 inch or less. of course, that doesn't mean its ok -- which is why this is only a temporary solution.
i sent my wife to lowes for some grade 5, 3/8 in width, 1 1/2 in length today. when i get them installed, i will see if the right size bolt solves the problem. if not, then i'll have to find some sleeves for the bolts -- which, i think will be hard to find.
rednck7736
rednck7736
Mississippi
Do you have the dust shield between the starter and trans.The bolt holes on my starter is bigger than the bolt on my bronco and F-150.But , the hole in the dust shield holds the starter in place and does not let it move.The starter fits snugly in place when I stick into the dust shield before I put the bolts in.
wolf83
wolf83
Lubbock, TX
i have some sort of dust shield -- it can be seen in one of the pics in my other thread. ... but it does not hold my starter in place snugly at all. i have to hold the starter in place with my hand until i get the first bolt started.
rednck7736
rednck7736
Mississippi
I have to hold mine in with one hand as well but once it is in.It is a snug fit.It want woble anything like that.
wolf83
wolf83
Lubbock, TX
sorry it took me so long to update...
my redneck solution only lasted a few starts, then the torque on the starter finally compressed the nylon zip ties until they were no longer holding the starter in place.
i tried more sophisticated - yet still redneck - ways (like using a sleeve to take up the gap in the bolt hole), but nothing worked any better. life moved on and i ran out of money, so i never fixed it.
after much thought i have come to the conclusion that the flexplate/flywheel was just too small in diameter by about an eighth of an inch - and i certainly wasn't going to replace that -- not in the carport of my driveway!
i finally sold that donor truck after taking off it what i could. all's well that ends well.
digs
