rear window trouble
hockeyfreak55
georgia
i have a '94 bronco, and my rear window doesn't want to roll up or down. i can get it up and down by turning the key and at the same either pushing the window up or down. what do i need to do to fix the problem?
rostheiceman
florida
crawl in the back and take off the panel get a test light turn on the key and have a friend try to roll it down and test to see if your getting power you might have blown a fuse or a moter
BroncoJoe19
It sounds to me that your rear window switch and motor is working, but it needs assisatance from you.
If so, You can lubricate the rubber seals a little with WD 40 (the ones that seal the track that the window rides in. Also, you may want to check the tailgate alignment perhaps the latch pin moved a little bit.
Its possible that the electrical connections are corroded, and although working... not allowing full amperage through to the motor.
There is a safety switch in the driver's side latch, and connectors usually behind the left tail-light.
If you take open the panel, you most certainhly will find things to ***** and possibly connections to clean.
rebel33382
Bob Labob
mine is starting to go down crooked, need to help it up myself, anyone know off hand what this might be?
Please don't hijack someone elses post. Make you own new post to prevent your question from being lost.
Bronco_Willis
Edmonds, WA
Not sure if you fixed the problem yet or not but here is what I did in this situation. After pulling the motor and testing it, it worked great. So I then pulled out the rear tailgate regulator I saw that it was corroded and pieces were not moving correctily. I cleaned off everything. Even pulled the rollers to clean under those. Then I put barring grease on all moving parts and WD40 on the spring itself. I put grease around the knobs for the rollers as well. I cleaned out the tracks for the rollers and even greased those. Now it works perfect.
seansz28
