rear springs
texan79&96
could you run 6" rear springs without the factory block to get 4" and then if i wanted to go 6" later put the block back in? im looking into the deaver springs and dont wanna have to spend that much 2x if i decide i need to go taller later on. the trucks being built around 35" tires with cut fenders to stay low and not break stuff all the time until i can afford some dana 60s.
Barto24
Plainfield, IL
check out:
http://sky-manufacturing.com/
i ordered the flip shackle from them, havent gotten it in yet, but pretty reasonable for a 4.5" lift. If you havent seen one before, the thing looks extreemly stong so im not worried about it breakin.
Maybe you could use this with the blocks to get you 6.5?
drubbz
