Rear Power Window Won't Work
shaun94
bronco commander
hooksett N.H.
Dose anybody have or know were i can get the wiring digram for the rear power window in my 88fsb. Any help would be great.
davids78bronco
fabricator extraordinaire
central Oregon
It's shown in a Haynes or Chilton's. If you don't have one, or can't get one, there SHOULD be one at your local library.
Does your switch work at the dash, or at the tailgate, or not at all? Have you checked for fuses, or relays?
azrockrat
kingman az
ok here ya go
from the dash there are two grounds
lt blue/blk goes to fuse #14
blk/wht comes from fuse#12
blk/wht splits in two
from the dash to tail gate switch is pink/lt grn for down
from dash to switch is pink/ltblue for up
from switch to motor is yel-red for up
from switch to tailgate sending unit istan-blk
and from sending unit to motor is red-yel
S
shaun94
bronco commander
hooksett N.H.
No problem now all i need to do is get the truck into a garage and of this damm cold New England weather. Thanks again.
Sufferedformula
