rear gears
brokenbronco666
point pleasent N.J.
hey. ok i lifted my 1986 ford bronco 6 in" and i put 35s" on it and now i have no power. i kno i need rear gears but i dont kno what gears i have in there now.in the stock 8.8 my boss said i have 3.09's . my friend said i have 4.11's in it. and the guy at M&M auto said 3.08 i dont kno who to believ. its funny b/c i can put a tranz in with no prob but when it comes to rear gears i m lost
fordfanatic75
martinez c.a.
20144[/snapback]
well now there are two very easy ways to tell, one is easier than the other, lets start with the real easy one, climb under the truck and try to find the tag, this will be a small metal strip probly bolted to the cover, if you find one look for the numbers it, if you have308 gears it would be 3 .08 if ti was 411 4 .11. now if theres no tag this one is garanteed to work! take the cover off and count the teeth on the ring gear, then count the teeth on the pinion gear and then divide the ring by the pinion, for insance if you have 37 teeth on the ring and 9 on the pinion you have 4.11 gears...
If the rear end has never been modified, then the axle code on the Safety Compliance sticker located on the driver side rear door post will provide the info. A code of 13 is 4.11; 16 is 3.50; 18 is 3.08; 19 is 3.54; If there is an H instead of a 1 then it is a limited slip differential.
An additional method would be to jack up the rear end, both sides. Put a mark on the drive shaft that you can see. Turn the rear wheel one turn and count the number of times the drive shaf turns, ex. just slightly over 3 you have 3.08, a little over 4 turns 4.11. Note: with an open differential you need two people, one for each wheel and turn at the same rate.
Keep in mind if you change the rear gear ratio, you need to change the front to match it. If you don't, you will have a real nasty experience when going into 4x4.
There is a real good chart in Jeffs Bronco Graveyard "80 and up", catalog to help you pick a gear ratio that is right for the way you intend to operate the truck. I believe it is on page 30. In your case 4.11 or 4.56 is probably the right set. Also keep inmind the chart is calibrated for 55 highway cruise so if you cruise at 65 then the numbers move up a couple of notches. Jeff gives a formula to let you calculate your own numbers. If you have 3.08's in there right now that will definately make you a power Dog with 35's on it.
I have 3.08's and with my 33's on it is a power Dog. I get taken off the line by snails :)) .
wtfdissux
Buffalo, NY
wasn't there also a 3:55 as well i know that my truck came with the 8.8 trak-lok using 3:55
The code "19" was open 3.54:1 in front and open 3.55:1 in the 8.8" rear axle. The "H9" is also an open 3.54 front, 3.55 rear with L/S or the Ford Traction-Lok.
And I agree that 4.56:1 gears are what you should run with 35" tall tires. That's what I plan to swap to in the near future on my 84 Bronco.
denny.dikes
