i dont mean to butt in on this guys thread but this is something i've been interested in for a while. i looked and my truck has the H9 so as you said i should have the factory l/s right? so i shouldnt worry about installing an aftermarket one right?mad, look at the axle code on the safety sticker on the driver's side door jamb. Axle code "I9" is open 3.55 gears, while "H9" is factory limited slip (L/S or lsd). Very few have the front L/S, which would be a "2" in the code as in "H92". With open rear and front axles (no L/S in either), you're basically in 2 wheel drive when in 4Hi or 4Lo. One rear tire and one front tire will each spin while the opposite tire will not. One way to combat this in the rear axle is to lightly apply the e-brake. Doesn't always work, though. JSM84
I thought that with a limited slip they spin the same way and with an open they go oposite? I've seen the inside of my diff and it's a confermed open diff and they spin oposite? Wait, I'm confused?
Whoa, whoa, whoa here guys. Everybody hold up here for a minute because there seems to be a LOT of confusion about this. Let's all start from scratch and take it one step at a time.if the front hubs are locked the 2 front tires will turn at the same time right but the rear end if you lose traction is basically useless without l/s right?
Chances are that it's a standard open differential but it's possible you have a traction-lock (just as a bit of general info, "posi" is an, uh, ahem, Chevy term. GM called their limited slip diffs "positraction" & street guys shortened it to "posi". Ford's are Track-loc)
You almost certainly have an open front diff, but again it's possible the original owner ordered it with track-loc's front & rear but Ford didn't make too many that weren't specifically ordered. Pretty much every truck that was built without a customer order was equiped with open diffs.
To ck and see what you have jack up the back of the truck so both wheels are off the ground. With the transmission in neutral spin one of the tires. If the other tire spins in the same direction you have an open differential and if it spins in the opposite direction you have a limited slip.
You unlock the front hubs because when they're locked it wears the **** out of them to be driven on dry pavement *in 4wheel-drive*. The front axle isn't like the rear since the tires turn. This creates a LOT of stress and the tires want to slip & scrub which they CAN do just fine on dirt or mud but pavement will cause the stresses to build until something breaks (usually a U-joint or axle shaft). You can feel this if you drive with them locked *and in 4WD* and turn in a circle. The tighter the radius becomes the more & more you'll feel a See-saw motion in the nose of the truck. Eventually you'll hear the tires starting to scrub & then shortly afterwards something will break. Off-road or in slippery conditions (sleet, ice, snow) it's no problem but again, on dry pavement you'll break something. Full-time 4x4's like the Blazer have this problem & owners learn to either make large diameter turns or install locking hubs so they can disconnect the wheels from the axles.yea i got all that, i was just hoping thats not the way it was?
but if thats the case why would you ever bother unlocking your front hubs?
just to prevent unnessary wear or what?
i don't understand this partalso when in 4X4 if it's really hard to turn on pavement, thats usually trac loc (hard chugging as both front wheels try and turn the same speed), most people find it annoying, but if you've got the track-loc front you'll usually have the trac loc rear, so you won't need 4X4 as much, both my bronco and my old explorer had track-loc front and back, the explorer had little trouble in a foot of wet heavy snow w/o 4X4, the bronco hasn't found any winter road conditions that 4X4 was absolutley needed, though it does help with turning in snow as well.
and another thing is if the front diff is open why would you worry about the front end jumping if the tired arent actually locked together?You unlock the front hubs because when they're locked it wears the **** out of them to be driven on dry pavement *in 4wheel-drive*. The front axle isn't like the rear since the tires turn. This creates a LOT of stress and the tires want to slip & scrub which they CAN do just fine on dirt or mud but pavement will cause the stresses to build until something breaks (usually a U-joint or axle shaft). You can feel this if you drive with them locked *and in 4WD* and turn in a circle. The tighter the radius becomes the more & more you'll feel a See-saw motion in the nose of the truck. Eventually you'll hear the tires starting to scrub & then shortly afterwards something will break. Off-road or in slippery conditions (sleet, ice, snow) it's no problem but again, on dry pavement you'll break something. Full-time 4x4's like the Blazer have this problem & owners learn to either make large diameter turns or install locking hubs so they can disconnect the wheels from the axles.
A lot of us will go for 5-6 months at a time an not unlock the hubs. The wear & breakage problem is only there when the axle is powered. If you have the hubs locked and the truck is in 2WD there's no problem because the axle isn't getting any power from the transfer case. when I lived in New England I would routinely lock the hubs in October and leave them locked until March. When I needed 4WD I'd shift the transfer case lever into 4Hi and I'd have 4WD, when I didn't need it I'd shift back to 2-Hi and leave the hubs locked.
/emoticons/[email protected] 2x" width="20" height="20" /> Ok, I can see you're still confused. I think the problem here is that you're dealing with two seperate things and not understanding it. First off there are the wheel hubs. Part-time 4WD trucks have hubs that lock & unlock (now don't confuse this with auto locking & manual locking hubs, they BOTH do the same thing, they just do it differently). What the hubs do is to essentially "disconnect" the wheels from the axle. When the hubs are unlocked the tires freewheel and even if the axle is recieving power fron the transfer case it is NOT being delivered to the wheels because they are physically disconnected from the axle. Once the hubs are locked the wheels are now parts of the drivetrain and can accept power from the axle and deliver it to the road. When the hubs are unlocked it doesn't matter WHAT type of differential is in the axle because the wheels are disconnected and recieve no power. If the hubs are NOT locked then the truck behaves just like a car or any other 2WD vehicle because it IS a 2WD vehicle when the hubs are unlockedand another thing is if the front diff is open why would you worry about the front end jumping if the tired arent actually locked together?
i guess part of my confusion is if the tires aren't locked and the diff is open then why are you see sawing and jumping around doesn't that mean the tires aren't slipping?
