Rear Axle Identification
challenger6pak
Missouri
Ok. I feel kind of stupid asking this question, but I don't know what rear axle I have. I just got the bronco.
It is a 67 with a 289 3 speed manual. It has 3.50 gears, 28 spline axles, and a third member just like the 9inch. Is it a 9 inch? What else could it be?
How can I identify?
thanks,
matt
BigNasty
SquirrelBait
NC
There shouild be a tag on the rear or possibly a vin sticker on the drivers door that might give trhe ID for the rear, if it hasn't been changed that is.
Regardless, the tag is prolly still on it, get the #s and someone here can prolly tell you for sure :) /emoticons/[email protected] 2x" width="20" height="20" />
C
challenger6pak
Missouri
No tag on the axle, the vin plate is long gone.
What other axles could it have possibly come with. Just the 8.8?
Is that also a third member axle?
Sorry, I am a mopar guy, this is my first Ford.
thanks,
matt
STLKIKN
Calgary Alberta
All EBs have 9" 28 spline rear diffs from the factory.
GVWR options could give you;
different size brakes
different size axle bearings.
C
challenger6pak
Missouri
Ok, in my Ford Service Manual it says that the rear ring gear diameter is either 8-3/4 or 9 in. Are both of these ring gears considered a 9in axle?
If I have the 8-3/4 ring can I switch to a 9 inch ring?
thanks,
matt
STLKIKN
Calgary Alberta
What year is the manual for?? All EBs came with the 9" rear diff.
No other rear axle options were available.
C
challenger6pak
Missouri
The Manual is for a 67, the correct year, and it is listed for the Bronco, not the Econoline or RV.
STLKIKN
Calgary Alberta
Hmmm, missed the "Ford" part of your service manual post.... sorry.
I have no idea why they would mention an 8 3/4 ring gear for the rear, neither of my manuals do. Only the nine inch is listed for the EB.
Your truck would not have had a vin plate/ sticker on the door jamb.
It would have been on the glovebox door, or in the case of the 66 and some early 67's the vin was located just above the e-brake pedal on the kick panel.
G
Guest
Guest
look at the bolts that hold the backing plate for the brakes on if they are like a 3/8"stud it has the big bearing rear end.
S_bolt19
Colorado
They never put a big bearing under an EB until like 74 or 75. A 60's vintage EB will have a 9" in the rear with most likely a Dana 30 up front. If the tag on the 9" is gone and so is the VIN tag, then there really isnt a way to tell what the gears are without opening it up. But I bet it is a 3.50 ratio.
custom_78
San Diego, CA
Someone could have swapped in a Ford 8". I don't know the size of the ring gear but you most likely have a 9". 8.8's didn't come around until 86 and they don't have a removable third member
79brnco
