I just bought a 1966 Ford Bronco from a private seller, I noticed that when I drive the car on freeways or at high speeds or RPM's, transmission fluid shoots out of the radiator from the tranny line going into the radiator at the top. I also noticed that the radiator looks like the original, does this mean my radiator is not cooling the tranny fluid enough which causes it to overheat and shoot out of my radiator? Should I get a secondary cooling system for the transsmission fluid? Do I need a new Radiator?
