putting 5.0 from 1998 econoline to 1990 ford bronco
90broncoon44s
Loxahatchee,Fl
i put a 5.0 out a 1998 ford econoline into my 1990 bronco but the ecm conecter from the harness on the moto does not match up with the on on my bronco do i need to buy a adapter or use the old harness from the original 1990 engine and if i do will that harness connect to the 1998 5.0 engine.. I NEED HELP PLEASE
yo 90broncoon44s,
WELCOME!
the 1998 Econoline ECM has 104 pins and your Bronco has 60 pins
Is it the 5.4?
I have not seen this done yet and I just know it is a big undertaking.
Use your Bronco's ECM & harness and then you will need to figure out which sensors & components to leave on the Bronco such as the MAP Sensor which is not used on the Econoline) and which to swap from Bronco engine or bay & how to wire, such as the Ignition Coil, Throttle Position Sensor (TPS) etc.
and what Sensors/components to swap from your Bronco into or onto the Engine (such as the coil, Intake Air Temp (IAT); (Air Charge Temperature [ACT] prior to 1992); Manifold Absolute Pressure (MAP); used only in Speed Density Systems such as your 90 Bronco; etc.
I'd keep the Bronco's coil, and see if TPS wiring can be used as well as other sensors and components
I have LINKs to many 90 Bronco wiring diagrams in my broncolinks.com site in the various component and sensor sections
Sensors @ http://www.broncolinks.com/index.php?index=134 - such as:
Idle Air Control (IAC); also called, Idle Air Bypass (IAB), Idle Speed Control (ISC), Throttle Bypass Air, Idle Bypass, Inlet Air Controller, Inlet Air Bypass, Intake Air Bypass, Intake Air Control
Wiring Diagram in a 90 Bronco by SeattleFSB (Seattle FSB) at http://www.supermotors.net/registry/media/851837
vs Econoline IAC wiring Diagram by AZ @ http://www.autozone.com/autozone/repairinfo/repairguide/repairGuideContent.jsp?pageId=0996b43f802e54ed'>http://www.autozone.com/autozone/repairinfo/repairguide/repairGuideContent.jsp?pageId=0996b43f802e54ed
BUT, I do not know if the Econoline IAC has same Resistance values as the Broncos IAC (7-12 ohms across pins) you can pull the Econo's IAC and see if it is same across the two pins
I do have the Bronco's ECM Pin Depiction and Legend, but not the Econoline's; you may be able to get it at Autozone.com's Repair Maual Section for free by registering there; http://www.autozone.com
EEC IV Connector Pin Legend by Ryan M (Fireguy50) @ http://oldfuelinjection.com/truckpinouts.html
EEC IV Connector Pin Depiction by Ryan M (Fireguy50)
http://fullsizebronco.com/forum/attachment.php?attachmentid=17644&stc=1&d=1313769200
yo, I overwrote an important topic; the ignition and wiring to the distr and ign module!
I have to think about what else is basically attached to the Econoline engine such as the distr and would need its wiring spliced into the Broncos harness
90broncoon44s
90broncoon44s
Loxahatchee,Fl
it is a 5.0 302 ...and when you say 'it is a big undertaking' what do you mean is it a good thing or bad? Also thanks for the information and links defenitly was somthing i needed
im also not shure if its a 96 or 98 econoline does this make a diffrence...
If it is a 96 or 98 then you'll need to figure out the sensor/component & wiring changes.
It is not a good thing, a huge job for someone without help or experience in electrical wiring and reading wiring diagrams
I have to think about what else is basically attached to the Econoline engine such as the distr and would need its wiring spliced into the Broncos harness; same for:
TPS,
IAC,
Engine Coolant Temperature (ECT) Sensor (for the ecm operation, not the temp gauge)
see this ECT location pic by Bill
http://i54.photobucket.com/albums/g91/subford/Electrical/Distributor/TempSenderPBMOD.jpg
and by Gacknar
http://www.supermotors.net/clubs/superford/registry/media/265237
Location pic in a 90 5.8 (intake manifold, driver side)
Source: by SeattleFSB (Seattle FSB) at http://www.supermotors.net/registry/media/837320
Throttle Position Sensor (TPS) pic
Source: by SeattleFSB (Seattle FSB) at http://www.supermotors.net/registry/media/857436
Test, Operational Description, Connector Pin-Out Diagrams & Parameters
Source: by Ryan M (Fireguy50) at http://oldfuelinjection.com/?p=30
all need to be researched to determine if sensor values are = to your Bronco's sensors; you can pull each from Econoline engine and measure w/meter or research for values.
Rons beast
Hey 90,
What M5 is telling you is that the 98 engine has sensors and reactive parts that the computer on your 90 does not have the ability to read and control.
The process for eliminating/and or changing those components and the related wiring can be a complicated process for an experianced tech.
Something similar was tried by another member here. The work was extensive and time consuming. The results were never satisfactory, as I recall.
The unfortunate action may be to pull the 98 out and get a 90 from a Bronc or truck.
yo 90,
Can you snap pics of the engine?
esp of the connectors showing the Pins for;
TPS
IAT
EGR's EVP
ECT
etc.
90broncoon44s
90broncoon44s
Loxahatchee,Fl
yes i can put up pics of engine and truck to give you more or less of an idea ... just give me till tomarow and ill post them up.... and guys i do not have the money for a new engine i actually should not be spending money or time on this truck i did a mistake from the begining buying it but im not a quiter i will not stop untill i drive this ****** atleast once then i will sell it! everything on the tuck is greaT BUT this harness deal .i really appresheate the help by the way and excuse my writing alot of words are miss spelled
Krafty
Ontario Canada
hey m5 I have a question for ya. if its a 5.0 set up with obdII would a 94-96 f150 or bronco harness and computer be the solution to his problems?
yo KRAFTY,
Yes it is. I suggested that he use his Bronco's ECM (PCM, EEC) & harness and figure out what Sensors/components to swap from his Bronco into or onto the Engine (such as the coil, Intake Air Temp (IAT); (Air Charge Temperature [ACT] prior to 1992); Manifold Absolute Pressure (MAP); used only in Speed Density Systems & prob TAD/TAB, etc.
Also add the ign Control Module from the Bronco & check wiring for any changes.
96 5.8 have no TAD/TAB etc in Air Injection (AIR), Secondary Air Injection, but 96 5.0 does have YAD/TAB and associated wiring & vac lines.
96 non Calif would have 3 Cats and wiring back to PCM; other years are diff.
IF it is a 5.0 & Since 98 engines are set-up for ODB II;
ALL OBD II Engines have MAF and no Manifold Absolute Pressure (MAP) Sensor; used only in Speed Density Systems;
Bronco Mass Air Flow (MAF) application:
5.0L - 1994
5.8L - 1995 (California)
5.8L - 1996
I have no idea of what else he can do exc to find someome say at a yard that has info or done this type of swap. I spent many weekend days at yards with my dad and uncles swapping engines, but that was a long time ago when LaSalles and Caddy engine swaps were rel ez to do.
I still have a Q on what the Econoline eng is; since 1997 the 5.0 was replaced by Ford w/4.6L 5.4L 4.2L & on-line sources show same engines for the 98 Econoline
BE WELL K!
Rons beast
how do i put pictures??
Hey 90,
Your pics have to be on your computer.
look at the lower left corner of this post. Click "reply". Under the bottom of the box you type in there is a small retangular box that says "browse..." Click that box, and find your pics on your computer. Click on the pic you want to post, and hit "open". That will put the pic info in the box to the left of the box that says, "Browse..." Below that click on "Attach This File." That will put the pic in your reply.
Repeat for any other pics.
Good luck
plugs3.jpgyo,
Can you snap a pic of the EGR tube too?
It will help with Identification, 5.0 & 5.8 EFI; They use different exhaust tubes to connect the EGR to the exhaust. The 5.0 gets exhaust from the lower intake, while the 5.8 gets exhaust from the passanger exhaust manifold
Such as;
Location Pic in a 96 5.0; w/ heat shield material attached to EGR valve (rusted brown w/ two clean nuts)
by miesk5
and
Location pic in a 95 5.0
Source: by cyclonegrey
Location pic in a 96 5.8 (from a 96 E250)
Source: by boss (bossind, Steve)
at a quick, but not complete glance, your plug wires look right for the 5.0
Here are pics of mine from driver side
and
Diagram for 94-96 5.0
Source: by Ford via Ian L (stangmata, stangmata50l, Bronco)
The adapter on econoline wouldn't be used anyway; we'll need more pics of all the electrical sensors, solenoids,& senders such as oil pressure, ECT and temp sender for temp gauge, Idle Air Control (IAC); Intake Air Temp (IAT); Throttle Position Sensor (TPS), Emissions (SEE LIST BELOW), coil, ign module, etc.
To see what most look like and where they are; see my site for;
Electical - http://www.broncolinks.com/index.php?index=134
SENSORS - Air Cleaner Temperature Sensor (ACTS); Crankshaft Position (CPS)/ Misfire Detection (MD); Engine Coolant Temperature (ECT), Idle Air Control (IAC) also called, Idle Air Bypass (IAB), Idle Speed Control (ISC), Throttle Bypass Air, Idle Bypass, Inlet Air Controller, Inlet Air Bypass, etc.; Intake Air Temp (IAT), (Air Charge Temperature [ACT] prior to 1992; Knock Sensor (KS) if equipped; Manifold Absolute Pressure (MAP); Throttle Position Sensor (TPS)
EMISSION;
http://www.broncolinks.com/index.php?index=24
Air Injection (AIR), Secondary Air Injection; Pump (Smog Pump), Thermactor Air Bypass (TAB) & Thermactor Air Diverter (TAD) Solenoids; Diverter, Check & Bypass Valves, Cross-Over Tube, etc.
Evaporative System - Canister Purge Solenoid Valve used in EEC IV, Carbon Canister (Charcoal Canister, Vapor Canister, Evaporative Emission (EVAP) Canister & Vapor Management Valve; miesk5 note; for OBD II, The vapor management valve (VMV) replaces the canister purge valve used in EEC IV; miesk5 note the Vapor Management Valve is located on passenger side firewall, high in our 96 5.0L
PCV
Exhaust Gas Re-circulation (EGR) System - Differential Pressure Feedback (DPFE), EGR Vacuum Regulator (EVR), EGR Vacuum Reservoir, EGR Valve Position (EVP), EGR Tube, EGR Valve
Electronic Fuel Injection
http://www.broncolinks.com/index.php?index=205
Fuel Injector
Mass Air Flow (MAF) Sensor
Fuel Pressure Regulator (FPR), Rail & Schrader Valve
IGNITION; plugs/wires firing orders & routing, distributors, MSD, ; Coil
http://www.broncolinks.com/index.php?index=30
http://www.broncolinks.com/index.php?index=230
Ignition Control Module (ICM)
yo 90broncoon44s,
I have been thinking about how to phrase what I have been trying to 'splain here and it came to me while @ NAPA getting an axle nut socket for the Hummer...
What can be done is to
ignore the Connector on the Van
try to swap all the stuff on the Bronco's engine to the Van's engine, such as those parts I have described in last post; TPS IAC, ECT etc. and plug in the connectors to those that are on the Bronco
Does the van have the MAF sensor in air intake tube(s) to throttle body?
If so, can't use that; have to keep your existing AIR FILTER BOX & Intake Air Temp (IAT); (Air Charge Temperature [ACT] prior to 1992)
