Pulling Codes Question
Outkast
Hayward, California
I know iv probably already said this but my truck is having shifting problems like downshifting into 1st is really rough and it feels like its shifting at the wrong times. So is it the transmission or the computer? My dad has an older ford code reader and i was wondering if it will work? and how do I go about pulling codes? I have never done it.
BroncoJoe19
Nick,
Pulling codes is easy, and I am guessing that your dad's older reader will work, if not all you need is a 4 inch piece of wire.
Your transmission should be a E4OD trans which is computer controlled, the two most important sensors are the TPS, and VSS, followed by your MAF, however, pulling codes should set you off in the right direction.
This thread is instructional and a number of members have used it. IF anything is not clear, please let me know so that I can make it more clear.
thanks
joe
http://broncozone.com/forums/index.php?s=&...ost&p=74581
B-Cack
My best advice is to listen to Bronco Joe, there is a reason he has an image of Yoda by his name. Good luck
