Pros And Cons Of Mini Spool
indoz
If anyone has the mini spools installed in their diff I would like to get opinions.
Thanks, Henk in hot West Australia( 104 today)
azrockrat
kingman az
i have one inb my 87 bronco with a 8.8 rear end great off road ok on road the rear end chirps and hopes when turning
I don't have it done yet, but I'm planning to spool my Ford 9" rear axle when I re-gear to 4.56 for my 35's. I've been doing alot of searching and getting opinions, too, in the last month or so. Much cheaper for a 9", but I have heard about the tires "chirping" when turning. Maybe it's like if you drive slow inside a building on slick concrete and it sounds like you're peeling out? I can live with that for the increased traction I will gain in back. Most folks do not recommend one for the front with the TTB, since they say it tends to break the axle shafts and u-joints.
G
Guest_indoz
Guest
Thanks for the advice gents, I think I can live with a birdie in the rear, so will install one in due time. Henk
bfisher1970
