Power window switch
Daddy's Big Truck
Hampton GA
Just got a replacement power window switch for the drivers side. Got the part from the Bronco Graveyard, but it does not look like the one that is currently on the truck. The new one has prongs, whereas the old one just has the wires soldered to the switch. Is there a way I can make my new switch work. Any advice will be greatly appreciated.
Well they weren't factory connected by soldering. The switch was attached by a connector that fits tight to the bottom of the switch. You sure that is not what you are looking at? Post a picture of the two.
Devil Dog08
philadelphia pa
what i did was take the electric door lock switch from the pass. door and put it in the drivers power window switch and put the old power window switch in the electric lock switch . all you have to do is break off the plastic tab. the ironic thing is now the window works and the power door lock works bo sides.....good luck
D
Daddy's Big Truck
Hampton GA
OK Call me stupid. Should have looked a little harder before crying for help. Got it figured out. Thanks for help anyway.
79brnco
