Passenger side window
wchampmd
Texas
From looking on ebay and other websites where broncos are for sale it seems to be a common problem of window problemsand Broncos. I own a 86 Full size Bronco w/ Power windows and my passenger side window needs assistance going up. The window motor does work (I think) but the window continues to slide down. When I am pulling the window up it goes up and the window motor is helping but as I drive it slowly starts back down. What is up with that? Anybody have any clues let me know. :huh:
firstford
The window motor has a plastic gear in it autozone sell the kit $19.00 i think its 3 or 4 screws its a simply fix and cheaper than buying a new window motor.Make sure the kit has the small tube of grease to put on the gear and it will work good as new.
crazyhorse85
clarksville,tenn
YEP,SOUNDS LIKE THE PLASTIC GEAR IS ABOUT GONE...THE KIT WILL PROBABLY FIX IT BUT ALSO THE MOTOR MAYBE ON THE WEAK SIDE AFTER FIXIN IT...I JUST OPTED TO REPLACE BOTH MOTORS AND BE SURE EVERYTHING WAS GOOD AND LUBED UP...BEING MINE IS AN 85 MODEL EVENTUALLY REPLACING WINDOW RUN CHANNEL HAD TO BE DONE THEY WERE COMPLETELY DRY ROTTED AND COMING APART...I KNOW JUST SOMETHING ELSE TOO THINK ABOUT...BUT NOTHING LAST FOREVER YOU FIGURE THESE BEASTS ARE 20YRS. OLD OR BETTER...OH THE MOTORS AUTOZONE HAS THEM FOR ABOUT 40 BUCKS APIECE NOT TOO BAD.. ONE PIECE AT A TIME BROTHER...HOPE THIS HELPS A LITTLE.... B)
jstevenson509
Spokane, Washington
They are correct. I'm going through that right now with my 79's rear window. I got the motor out and the wheel gear spun, but the plastic casing that the metal gear was housed in was stripped, sound exactly like the kit they're talking about. However, I've found in many places motors for $30. I personally feel like spending the extra ten to get new everything.. Just another option for ya!
firstford
the motor is still good it has a plastic gear that always breaks you get the kit at the part store down south its $19.00 not sure were u are but it shouldnt be that much and its cheaper then buying a motor and its a easy fix.
W
wchampmd
Texas
Thanks alot I changed the gear and the window works fine..Took five minutes.
