yo!
ok, that's good exc. for having to spend da $ on a rebuilt unit, but ** happens.
As far as da smog stuff; I prefer to leave it in; aside from State Inspection Laws and Fed Laws and our breathing in particular...
Some have removed it bec of mech problems;
Removal, Belt Part Number in an 89 5.8; NAPA Belt Part # 060825 Source: by Cucamongan (Scotty) at SuperMotors.net
For the rest of da AIR sys; you'll prob get a check eng light; but will run ok with all those vac hoses/ports plugged.
GL
some backgrnd info for the heckuva it...
Overview & Diagram"...The 2ndry air system is known to fail in a wide variety of ways. The check valves that prevent hot exhaust from entering the rubber hoses age, rust, leak, & crack open melting the plastic TAB & TAD valves, creating exhaust leaks that can damage other components, raising exhaust oxygen levels (setting lean codes or rich adaptive limit codes), and making rattling noises. The hard steel tubing between the exhaust & the check valve can rust or crack (especially the infamous "crossover tube" on the backs of V8 heads). The vacuum controls leak (including the coffee can reservoir on the R wheelwell) (Miesk5 NOTE, this is the Vacuum Reservoir (VRESER), it stores excess vacuum to prevent rapid fluctuations and sudden drops in a vacuum signal, such as during acceleration) get misrouted during other repairs, or the diaphragms rupture. The electronics that control the vacuum controls can fail electrically or mechanically, or the wires can be damaged. But all of these failures are either A) relatively cheap & easy to repair, or B) cheap & easy to prevent with normal inspection & maintenance..."
Overview; "...The thermactor bypass and diverter valves are actuated by small solenoids called TAB (thermactor-air-bypass) and TAD (thermactor-air-diverter) valves. The computer tells the solenoids to open/close, and the solenoids in turn direct vacuum to the the actual diverter and bypass valves.The TAB and TAD solenoids are prone to failure and when they do fail the problem can be difficult to diagnose. However, the symptoms are: 1) stalling after you come to a stop. 2) "lean" code 3) "EVP outside of tolerance" code 4) rough idle I think I paid about $45 each for the two solenoids. Also replaced the one for the EGR valve -- it checked good, but looked identical so I figured it would probably go next..."
Source: by RVcams
The only components in the Secondary Air Injection system that the ECU talks to are the TAB (Thermactor Air Bypass) and TAD (Thermactor Air Diverter) solenoids. On the F-series, these may also be called AM1 and AM2 solenoids (AM for Air Management). by GT 0909
