newbie need help with rear swap
72shadetree
Bassett Virginia
hi i got a 90 with eaod and 8.8 rear and im going to swap a 9in from a 86 with c6 into the 90.wich yolk or driveshaft do i need to use or will the 90 shaft bolt to the 86 9in yolk.
also will i have to change the rubber brake line
thanks for any help you can give me
Txquadhunter
N. Texas
17927[/snapback]
your 90 shaft will work just pull the ****** off used to bolt to the 8.8.. But your speedo won't work with the 9" due to the speedo using a ring in the 8.8 and not a cable into the tranny like the 9" use
72shadetree
72shadetree
Bassett Virginia
17937[/snapback]
ok thanks for the help
79bigbronco
Calgary, Alberta, Canada
depending what trans u have in there u'r trans may not shift right, there is an adaptor available that I read about in a four wheeler mag from a couple of months ago, let me know if u need the info on it :)>-
