Your air filter was soaked with what? Gas? Water?Thanks man! yeah it was only ******* for a few hours cause it hit 70 degrees in jersey and i was dying to check it out. I also rigged up 2 backseats sideways in the back so it was alot easier with the top off to get them set up. I am having terrible problems now though after this sunday. the only conclusion ive come up with so far is it might actually be hydro locked! uhh but no worries, im not giving up on this thing, ill swap the motor if i have to. any input on obvious signs if its hydro locked? i never buried the thing but the air filter on the intake was/is soaking wet. im new to the truckin world after getting rid of my fox body mustang and this is dampering my fun! any input or help would be great...thanks again for the welcome!
So the starter is turning? If not that my indicate you have gotten too much water in the starter or solinoid. If it is turning over but nto firing your ignition system my be too wet, check the coil packs (I think that is right for that year), plug wires, even your alternator may be drenched.Yeah i took off the intake actually and it didnt make much of a difference. Im gonna try the starter fluid trick this afternoon. All i was doing was hitting some trails with some huge puddles. (about 3 feet deep and at times 40 to 50 feet long.) its nothing my truck cant handle. i got a 4 inch body lift with 35 in tsl boggers. i didnt hit any puddles at 30 mph either. i was just crawling through them to avoid any problems like this. the truck shut off at one point shifting from reverse to drive but started right back up. then i lost power again coming out of a puddle and needed a tow 40 miles all the way back to my house. i thought it might just be a bad battery connection cause power was coming and going but once i fixed that it still wouldnt turn over and now makes a completely different noise. it does sound like its just all clogged up but idk. thanks for your help so far.
