Need Suggestions
Dulmer
Pennsylvania
Hey guys I need help with unlock my steering wheel and gear shifter even while the truck is off. I added a push start system but I don’t want to have to use that keys to unlock the wheel and shift. What can I do?
I know I can take the switch out at the bottom of the actuator the the key moves. But I still what the key in in case I need to start the truck that way.
Thanks for all and any help!
BroncoJoe19
New Jersey
I suppose that you can pull the ignition lock cylinder, and bring it to a lock smith who can make it so that you don't need a key. THen you can simply turn the key/switch to ON/RUN and push the start button, or totally eliminate the start button, and just turn the ignition switch to Start!
You can pull the steering wheel and remove the lock portion of the ignition linkage.
