need some help
tig
hey ya'll Merry Christmas and Happy new year !!! i need some help with my 83 bronco..first problem is the key sticks really bad when i try to start it, so i want to put a push button and a toggle switch in it, but i cant find any info on what wires i need to cut under the dash...second prob is a weird sqeaking noise i get when i turn left ,sounds like metal to metal ,but i cant find any wear on anything...dust shield maybe?? just put new bearing/seals in wheels and spindles...lookin forward to bein a part of the forum !!!!
thanks,
Tig
Welcome to the Zone > . Post some pictures when you get a chance, we'd like to take a :-B at them.
Could be a bent dust shield, hard to tell without looking at them. As far as the sticking key, if you mean it doesn't return the way it should, try some WD40 on the cylinder. Also it may be a bad spring in the actual switch that is operated by the push rod which the key cylinder operates. The actual switch is on top of the steering column just under the dash. Try removing the plug and spraying it with contact cleaner. If the switch spring is bad, it is an easy part to replace and align. I don't recommend the approach you are suggesting but here is a diagram.
T
tig
Thanks Seabronc !! i saved the pics u posted,i'll check em out tomorrow...the key doesnt want to return after starting..u have to turn it back to the run position,and its a bear to turn !!
i gotta get to bed,but thanks for the help,i'll try lookin @ the rod and switch under the dash..already did the wd40 thing,it didnt help....
nelbur
The old grease in the gear and rack behind the key cylinder is known to get stiff in the cold, making it difficult to turn the key. Some have broken the *** metal parts. The proper fix is to disassemble the parts, clean the grease off and re-**** with thin ****. Things have to be put back just so, so it is not for the average DIYer. However, if you have a tilt column, it is easy to remove the cylinder, spray thin oil back on the gear, which will dilute the stiff grease and keep the key working. If something is not done, you may well break the works.
With a tilt column there is a hole near the base of the cylinder that will allow you to release the cylinder, (non-tilt requires the steering wheel to come off to get to the release hole.) Disconnect the battery. Turn the key to the run position. Mark the column so you can re-install the cylinder in the run position. Now push a pin punch or stiff wire into the release hole and remove the cylinder with the key still in it. The cylinder has a flattened shaft at the back that indexes into a gear, with a rack above it that slides a rod up and down the steering column to work the ignition switch, which is just behind the dash. Remove all the grease you can with a small ***** driver. What you see is not the gear, but rather a washer like bearing that holds the gear in place with a snap ring keeping the parts together. Do not remove the snap ring. Just spray a lot of lite oil over everything and into the hole in the gear. Reinstall the cylinder in the run position and work the key from Start to ACC. repeatedly to work the thin **** into the stiff grease. This is much easier to do than to tell about it. I used SuperLube spray as the thin oil.) My key turns much better but is not as easy as I would like. I will probably do it again next winter.
Hope this helps keep someone from breaking their key workings.
eholt80
