yo Mike!
WELCOME!
What color smoke? black, blue or white?
Black smoke = rich fuel mixture;
check air filter
pull Red (could be discolored or replaced by a prev owner w/black line) vacuum line off of Fuel Pressure Regulator (FPR); any sign of gas aroma or gas in the line = bad FPR (see below)
vacuum leak (see below)
a sensor
leaky fuel injector
Blue smoke = engine wear or damage
pull a few spark plugs and check for fouling & gap (see below)
White smoke = coolant leak, usually through head gasket
check coolant recovery tank level; if low after filling to mark and running for awhile.
- Check dipstick,any signs of chocolate milk = coolant; or gas aroma = gas in crankcase
Did you do both tests for Codes under following conditions?
The engine temperature must be greater than 50°F (10°C) to pass the KOEO Self-Test and greater than 180°F (82°C) to pass the KOER Self-Test.
............ if not;
Try a Self Test for Codes by our bro-in-grease here, BroncoJoe19 @
http://broncozone.com/topic/14269-code-reader/page__pid__74587__mode__threaded
An assistant to write the info is helpful
heat the engine up; idle until temp gauge is in normal range you usually see
and when it warms up; shift thru all gears incl Reverse anyway.
Then turn off all accessories/lights, etc.
Make sure A/C is off and transmission is in Park (automatic)
Do Key On Engine Off (KOEO) portion first.
Look Codes up in my broncolinks.com site using the new Search function if in a hurry today.
And Post em here according to
KOEO
& KOER
Location pics by Cole; driver side of intake manifold
Vacuum Leak Test; On an idling engine check for vacuum leaks using a mechanic's stethoscope with the probe removed, or a ~3' garden hose section. On COLD ENGINE only, use propane torch w/rubber hose attached, UNLIT or spray carb cleaner, when it gets to the the leak the RPMs will rise. Also check: vacuum hoses; intake manifold gasket & throttle body; PCV line; vacuum reservoirs: EGR Sys Vacuum Tank & 2ndry air (coffee can); AC, heater, defroster, vent control ckt & vacuum tank (plastic ball type), under dash & lines to heat/blend/etc. doors; power brake booster; cruise control ckt, etc. Where applicable; BEWARE OF BELTS/PULLEYS, FAN AND HOT ENGINE
Source: by miesk5 at Ford Bronco Zone Forums
Spark Plug Firing End Analysis, General
Source: by gnttype.org @
http://www.gnttype.org/techarea/engine/plugs.html
Timing & Plug Gar/Type for your year, engine, etc can be found on sticker atop radiator; if missing;
Vehicle Emission Control Information (VECI) Decal; Contains Vacuum Diagram & Calibration Parts List for 88 & UP.
On-Line for Free at Ford.
Click "Quick Guides" in left panel; Scroll to & CLICK VECI Labels "Provides Vehicle Emission Control Information (VECI)
and a related calibration parts list." Enter applicable info (
need to know your Calibration number from your B-pillar sticker). Vacuum Diagram is the same as the one on the core support or hood or air filter cover. Suggest Right Clicking this Hot Link & Open in New Window
Source: by Ford @
http://www.motorcraftservice.com
FGo thru the drill, select: 1993 "light truck", 5.0
Timing
Adjustment in Ford EFI Engines; MIESK5 NOTE; Spark timing that is ******** from specification may increase exhaust gas temperature and shorten catalyst life. Refer to the following procedure for service details. a. Check spark timing. Check base timing with spout disconnected. Set base timing to the specification on the vehicle emission decal. b. Check computed timing with spout connected. NOTE: COMPUTED TIMING IS EQUAL TO BASE TIMING PLUS 20° BTDC ± 3°.
Source: by Ryan M (Fireguy50) at
http://fordfuelinjection.com/index.php?p=71
btw, your SPOUT connector is on the driver side inner fender near hood hinge
EEC IV Strategies
Source: by Ford via miesk5
Figure on using just the Cold Driveaway:
Can be:
Timing
PIP (not likely since it will do opposite of going bad under heat, etc.)
MAF (no MAF on your yr)
TPS, ECT, ACT, NDS (neutral drive safety switch)
Operational Sequence, Depiction & Wiring Diagram in a 94; "...When the ignition is switched to the ON position, it turns the EEC Power Relay on. The EEC Power Relay provides power to the EEC-IV processor and the control side of the fuel pump relay. Power for the fuel pump is supplied through a fuse link or high current fuse attached to the starter solenoid (battery side). From the fuse link or high current fuse, current flow is through the fuel pump relay and Inertia Fuel Shutoff (IFS) switch to the fuel pump. The IFS switch is a safety device used to shut off the fuel pump in the event of a collision. If the IFS switch is "tripped," it must be reset by depressing the white or red button on the top of the switch. The fuel pump relay is controlled by the Powertrain Control Module (PCM). When the ignition switch is turned to the ON position, the fuel pump will operate. If the ignition switch is not turned to the START position, the PCM will shut the fuel pump off after approximately one second. The PCM will operate the fuel pump when the ignition is in the START position to provide fuel while cranking.After the engine starts, the PCM will continue to operate the fuel pump unless the engine stops, engine speed drops below 120 rpm, or the IFS switch is "tripped."
Note: Grounding the FP lead at the DLC will allow the pump to run continuously with the ignition switch on.
Rough idle, hesitation, poor throttle response, induction backfire and stalls during cold start/warm up may be caused by the poor volatility of some high octane premium grade unleaded fuels (91 octane or higher (R+M)/2); in Tips to Avoid Lean Conditions TSB 91-8-13; "...Rough idle, hesitation, poor throttle response, induction backfire and stalls during cold start/warm up may be caused by the poor volatility of some high octane premium grade unleaded fuels (91 octane or higher (R+M)/2). When compared to regular grade unleaded fuel (87 octane (R+M)/2), high octane premium grade unleaded fuel may cause long crank time.ACTION: Use a regular grade unleaded fuel in all vehicles, except where a premium unleaded fuel is recommended in the Owner Guide. If lean air-fuel type symptoms are experienced, determine the grade and brand of fuel used and offer the following service tips. Advise those using a higher octane grade fuel to switch to a regular grade unleaded fuel. For those using a regular grade fuel, advise them to try another brand. Do not advise using a higher octane unleaded fuel than is recommended for that specific engine. Ford engines are designed to perform best using a high quality regular grade unleaded fuel. Only advise using a higher octane unleaded fuel to avoid potentially damaging spark knock or ping, but do so only after mechanical fixes are ineffective. NOTE: ALL UNLEADED GASOLINES USED SHOULD CONTAIN DETERGENT ADDITIVES THAT ARE ADVERTISED AS HAVING "KEEP CLEAN" OR "CLEAN UP" PERFORMANCE FOR BOTH INTAKEVALVES AND FUEL INJECTORS..."
Source: by Ford
