need help
S_bolt19
Colorado
Dude, you aren't really giving any information here. If you would tell us from the get go what you have done & what not, we wouldn't be taking stabs in the dark on this. By measuring a track bar, that doesn't do much. Those things should be the same length from rig to rig, as long as they are 78-79 with a solid axle 44. The other thing, some of those bushings for the back of the radius arm have caster built into them. If you have them installed wrong, that is going to shove things around too. Also the c-bushings have to be installed correctly too, there is an upper & lower side on each bushing.
G
george
the c bushings are in the right way and the rear radius arm bushing are stock ford tipe this has been a problem sins i have had the bronco i have other 79 4x4 that i have tried takeing measurd from a cant find a dif it is off b 2 inchs the pitming arm is stock
If everything is new and it drives straight leave it be. It wont hurt anything
G
george
i took mesherments and they are so close to the same idid not spend 3 grand on the body and tiers to look stupid and it does not stear good thats why i am tring to fix it it stears like crap thanks foure the ideas
rdbrnc96
i know this may sound silly but maybe you should measure your rims you may have 2 inch wider rim than the rest idk could be it just a stab in the dark
but if everything is new and all the measurements are fine then that could be it and why it may pull to one side who knows the hardest problems to solve are the ones that have the easiest solutions
Baltimore773
