Need Help With Manual Transmission
gearheadmike
Ok i got a full size bronco 302 5 speed well i just lost 1st&2nd gears in it and i found a transmission in a 91 f150 6cyl 5 speed 4x4 its got 1000 less miles then mine and is a good deal im just not sure if it will work/bolt up? I know a replacment transmission from autozone has the same part number for both trucks
but doesnt mine have the electronic sensor for the speedometer and the 91 has a cable?
yo MIKE,
You have a 96, correct?
If So,
You do have the PSOM and will not need the xpeedo cable
Both trans are Probably Mazda M5OD-R2
Here is an overview
Depiction & Overview
I do Not have any info on the year swap to confirm it will work out well, but can ASSUME it will since the donor is a 4x4
See more M5OD info Links in my site @ http://www.broncolinks.com/index.php?index=57
such as;
M5OD Disassembly & Assembly Procedures
Identification Tag Depiction; located on the driver's side of the case, except New Process
Mgough
