Need Help Identifying Transmission Application
3 speed w/od
I have been told that the following transmission may have been installed in Broncos of '84 thru '87 vintage. If this is true, I would greatly appreciate know in which years this transmission was installed.
- 3 speed w/od (4th gear is od)
- aluminum case
- first letters on case tag is "RTS"
- top loaded transmission
- shift tower is on top of case
Thanks
The top-mounted shifter 4-speed overdrive (TOD) was available from 1980-1987 according to the Haynes Manual.
Staff online
Sufferedformula
