My bronco wont accelerate past 45.. PLEASE HELP!!!!&#3
bronconewbie9369
Texas
I have a 93' ford bronco full size and whenever I turn it on the engine seems to really shake hard for a couple of seconds on and off, as i put it in drive and try to accelerate past 45 or so or get out of 2nd gear it seems when i push my foot down on the accelerator that it just sputters and wont accelerate or slowly creeps up to a higher speed. what could the problems be? possibly fuel filter? oil change? something more serious?
Brwbronco
Is it carburetor or fuel injected?
Brwbronco
It could be a clogged fuel filter. If its carburetor its more likely to be a clogged jet or circuit in the carburetor. If it has been a while or your not sure when it was last cleaned out it wont help and its fairly easy. The hardest part is normally finding a carb # (which should be on the carb or look it up in a chilton book). After that buying a kit is easy and fairly cheap. The kit should include a diagram/instructions. If thats not the problem then I'm not sure but I'll ask around.
Krafty
Ontario Canada
my guess is its an efi being a 93. Tune up first and foremost. spark plugs, wires distributor cap and rotor,and fuel filter.
then if problem persists begin testing fuel pressure, ignition timing, and throttle position sensor.
yo bronconewbie9369,
WELCOME!
Try a Self Test for Diagnostic Trouble Codes (DTC)s by my pal, BroncoJoe19
http://broncozone.com/topic/14269-code-reader/page__pid__74587__mode__threaded
Run it around to heat the engine up and shift thru all gears incl Reverse. Then turn off all accessories/lights, etc.
Do Key On Engine Off (KOEO) portion first.
Look Codes up in my broncolinks.com site using the new Search function.
And Post em here according to:
KOEO
KOER
Joe also shows how to ck for vacuum leak.
Here is a typical List of possible causes;
probstStallsQuitsonAccelerationorCruiseSurgesonCruiseRuns RoughonAccelerationCruiseBackfires.JPG
So, we try to do the Self Test first and then vac leaks because they are @ top of List in most troubleshooting Category steps and are FREE
btw,
Jeff at the Bronco Graveyard has offered a 2% discount to members of The BroncoZone for on line orders. To get your discount, enter the discount code BZMEMBER. Also you must include your BroncoZone User Name with the order.
http://broncograveyard.com
Brwbronco
Oh ok. Thanks Krafty learn something new every day. I own a 96 chevy Blazer with fuel injection and I have problems with the darn thing more than anything.
BobButtertone
