Motor Identification
brentusbrutus
canada
Hi again..
84 bronco, automatic, 302, Motorcraft 8191 A Carburator.
How do I figure out what year my motor is? I know it isn't an 84 'cause it's been replaced.
Thanks folks!
highboy73
FORDing thru life
morocco,indiana
if you could get the casting number off the block i could check my book and see wht it says.should be under the starter
Bulldozer
they don't usually have the year on them, some might have a cerial number
sweepersrgr8
"GET ER DONE"
Charleston,SC
The first two digits of the casting # on the block or heads is the year. The first digit will be a letter, indicating the decade C='60's, D='70's, E='80's, and so on. The second will be a # indicating the year. For example if your casting # is E4OE-#####, you engine is an '84 year model.
brentusbrutus
canada
Took off the starter, and there it was, covered in grime..
The Casting Number is
ENGINE: D2OE-6015-AB-2E1
Looks like you have a 72 Fairlane or Torino engine block.
Do you know if it was rebuilt before being installed in your truck? If so, those were great blocks to do a rebuild on. The 75 - early 84 blocks had a lot of cracking problems due to poor workmenship.
Thw oil amount shouldn't be any different than normal. You can check the dipstick after refill, should be 5-5-1/2 quarts. I would also search some of the Ford sites about the casting number to see exactly what you have. You might just have a rare block that can accept some great mods!!!
brentusbrutus
canada
the dipstick is my next small problem..
tHE one i have is busted, so i am trying to figure out which one to order from Ford...
..What kind of Mods would you be referring to?
