map
jose
hellow friends,i have a bronco 1988,302.4x4,i clean the iac ,putnew spark plug,and idle is somethime irregular, i whant toclean the map,but idont know where is located,thanks a lot jose. :)>-
yo Jose,
Location pic in an 88 302 (5.0)
Source: by Jem270
More MAP info LINKs in my site @ http://www.broncolinks.com/index.php?index=138
Did you do a self test done yet?
a Self Test by BroncoJoe19 @ http://broncozone.com/topic/14269-code-reader/page__pid__74587__mode__threaded
do the KOEO = Key On Engine Off portion first & Remember to have engine @ Normal Operating Temperature before doing the KEY ON ENGINE RUNNING (KOER) portion
Some Guesses
Idle or Stalling Problems & Troubleshooting; "...The IAC is usually a cylindrical unit attached to the upper intake manifold. This unit electrically controlled by the computer, and allows air to flow into the intake at idle, bypassing the throttle plate. The extra air is accompanied by extra fuel to bring the idle up to proper speed, and when cold, allows a high idle condition. These units may become dirty, and need cleaning. Many idle and stalling issues tend to be blamed on these units. Cleaning is achieved by removing the electrical connector, and two screws holding it on. Once off of the vehicle, clean with throttle body cleaner (or a good carburetor cleaner). Continue cleaning until unit is clean, like new; reinstall unit. This is also a good time to clean the intake, and EGR ports (if applicable). Testing may be achieved by bringing the engine to operating temperature, noting the idle speed (should be within spec). Unplug the unit’s electrical connector, and the idle should drop to about 650 RPM. When the unit is reinstalled, it should return to normal idle speed. If the vehicle does not idle at proper RPM (too low), there are no vacuum leaks, and the TPS calibration is correct, than the unit is most likely fault..."
Source: by broncoii.org
Idle Air Control (IAC) Sludge; Poor Idle TSB 91-25-07 for 85-92 Bronco & F Series & many others; "...Hard cold starts, hesitation and stalls on initial start-up or during idle or decel may be caused by sludge in the throttle body and/or idle by-pass valve. Sludge deposits or oil film on the throttle body bore and plate or the idle air by-pass valve may cause one or more of the following conditions. Hard Cold Start, Stall On Initial Start-Up, Stall During Idle, Stall During Decel, Rough Idle, Rolling Idle, Hesitation During Acceleration. A new idle air by-pass service kit (F2PZ-9F939-A) is now available for service use to correct sludge contamination concerns of the throttle bore and plate only. It eliminates the need to clean the majority of past model throttle body applications. Cleaning is not required on sludge tolerant throttle body designs released for 1991 and newer model years..."
Source: by Ford via Steve83 (Steve, That dirty old truck) at http://www.supermotors.net/registry/media/724437
also an EGR valve that’s stuck open will act like a vacuum leak and cause a rough idle and stalling
Vacuum Leak Test; On an idling engine check for vacuum leaks using a mechanic's stethoscope with the probe removed, or a ~3' garden hose section. Don't spray flammables on a running engine. MIESK5 NOTE; Also check: vacuum hoses; intake manifold gasket & throttle body; PCV line; vacuum reservoirs: EGR Sys Vacuum Tank & 2ndry air (coffee can); AC, heater, defroster, vent control ckt & vacuum tank (plastic ball type), under dash & lines to heat/blend/etc. doors; power brake booster; cruise control ckt, etc.... where applicable; (combined w/ Steve83's info, thnx) BEWARE OF BELTS/PULLEYS, FAN AND HOT ENGINE
Source: by miesk5 & Steve83 at Ford Bronco Zone Forums
GL!
teejayd9
