Lights flickering
Thats different.
There is a bundle of wires in that area that go through the firewall. sounds like it might be worth taking the time to check each wire and wire connection 1 by 1 to see if any are getting pulled on or push around. Also check on the engine by side of the firewall.
Yo Keith,
In addition to Skitter's suggestion, check GROUND G801 for driver side headlight located on driver side inner fender behind headlight...
and G802 for passenger side headlight located on passenger rside inner fender behind headlight.
Also, with headlights on, do feel any heat around the headlight switch or it's connector/pigtail?
