Leveling kit
ProPain
Bristol, VA
Ok im going to put a leveling kit on my 94 I know it will need an aligntment afterwards my question is will I need those after market adjustable alignment things not sure what there called exactlly
koontreeguy
western mass
the leveling kits only raise ur front end by 2 inches . I don't believe u would need an alighnment (75% sure about that) . my buddy did the same thing with his 250 and just drove it like it was and never complained
The part is called an "adjustable camber bushing", which sits atop the upper balljoint on easch front side of the TTB. You will need an alignment with the leveling kit, and some people have had problems keeping the frontend aligned with the leveling kits. What type of camber bushings do you have now? Take alook at them from above to see if the bolt hole thru the bushing is in the center (concentric) or off to one side (eccentric). The eccentric ones do not have enough range to adjust for the leveling kit - only about 1/2" lift maximum. JSM84
