cpratt1999
My 93 351w Bronco has been a world of trouble these last few months. I recently replaced the engine, heads, intake/plenum, roller rockers, cam (twice) etc. and it would not start. I later discovered that the heads I had ordered were two different versions of the E7 heads, and were questionably shot. So I replaced the heads after cleaning out the old ones thoroughly.
Well long story short; I have now replaced the battery, cables, ground wires to the engine and battery, the battery cables, and every wire connecting to the starter. I replaced the OE one because it had finally seized (and after 210k miles it did pretty darn good if you ask me), and I replaced it with a high torque starter that I had purchased from www.dbelectrical.com. It cranked a few times, and now it just clicks. I tried re-wiring the power/grounds, and I even tested the wiring to ensure that I am getting 12.5-13 volts (which I seem to be).
It's possible that I may have just gotten another defective starter since it's typically hit or miss with reman. parts, but before I fork out 150 bones to buy a high-torque/new starter-is it possible that something else may be causing the starters to repeatedly fail?
