just joined
kevin
i've got a big block in my 82 bronco there isn't much info about them in australia just wondering if any one can help me with bigger diffs so i dont break them my big block puts out 490 hp at 1374 foot pounds
Welcome to the Zone. Post some pictures and also put some in your member photo album.
Wow, sounds like you need to upgrade your axles to Dana 60. That engine will definately do damage to the Dana 44's that come with the truck.
K
kevin
Welsome to the Zone. Post some pictures and also put some in your member photo album.
Wow, sounds like you need to upgrade your axles to Dana 60.  That engine will definately do dammage to the Dana 44's that come with the truck.
Goood luck,
22904[/snapback]
THANKS FOR THAT i'm in aussie some times it's hard to get those parts but i will check out f spares the bronco i have got i imported it myslef from calafornia i think thats how its spelt the motor is a brand new crate motor them striped down has a knife edge crank flowed heads solid cam with rolla rockers port matched with headers it might get pulled down again soon and balance it do u think that is nessery it seems to vibrate at about 5 and a half thousand rpms
As far as Dana 60's go, I guess the availability of older Ford F350's in your area will be a key issue. Here is link to a gold mine of information for Dana 60's http://www.pirate4x4.com/tech/billavista/60_front/
I just spent a hour browsing thru that site :ph34r: /emoticons/ph34r@2x.png 2x" width="20" height="20" /> . Real interesting :-B .
K
kevin
22922[/snapback]
thanks for that i will give it a look hopfully i will find some thing i think i know were a f350 my be they r wrecking it so i hope i can get the parts that i need
Welcome to Bronco Zone!!! I think Seabronc has you on the right track for the D60/D70 axles. Good luck with the engine problem, too.
indoz
22888[/snapback]
G'day Kevin, which big block did you get, and what is your drivetrain set-up?
There are a few good supliers of parts here in Oz.
Henk from Oz
K
kevin
G'day Kevin, which big block did you get, and what is your drivetrain set-up?There are a few good supliers of parts here in Oz.
Henk from Oz
22954[/snapback]
the motor was a create motor from the states it was just a stanterd 460 its had a bit of work now we imported a trans form the same place had it mod to suit the exrta power it was all done threw a mate of mine that was living in the states at the time he has since moved up to alaska so he cant help me ant more .what part of oz r u in
K
kevin
22932[/snapback]
thanks for that i've got f spares in the sunshine coast looking for some hope they can get hold of some .I think the engine prob might go away if i stop stamping on the loud pedal or spend more money on it might be easyer to spend the money. I love that big block niose can get enought
indoz
Kevin, I am in Perth, I often use Superoo wreckers, they do Ford parts only and are reasonably cheap, another is Suburbanimports, web site only, just Google these names to have a look, which series is your 460, which heads?
Henk From Oz
K
kevin
Kevin, I am in Perth, I often use Superoo wreckers, they do Ford parts only and are reasonably cheap, another is Suburbanimports, web site only, just Google these names to have a look, which series is your 460, which heads?Henk From Oz
23005[/snapback]
i'm not sure what one it is but a mate of mine imported it for me he didn't say what model it was for the box came with it not sure what the box is but the whole lot works ok i have been trying to get hold of him to find out what it is but he has moved to alaska he hasn't got hold of me untill then i don't know .The heads where port and flowed by a machine shop in archerfield in brissy i have had alot of machining done by him he's good .We r looking at traveling around aussie once our caravan is finished we might b over there in about 3 years or so might b able to catch ya
K
kevin
Welcome to the zone!!!
Colleen
22994[/snapback]
thanks colleen it tolk me a while to find the site but i got here i didn't think there were so many people in to ford broncos out there guess that means im not the only hp freak lol
wrachet
Kansas City Area
23015[/snapback]
I was quite surprised myself!!! Amazing what a little search on the internet can bring!!!
Colleen
Hey Kevin, I worked in and around Moree in NSW for a few months awhile back ,and was surprised by the number of Ford vehicles the blokes drove. I even found a supplier for my shaker assembly from 'down under', so alot of us in the States have connections over there. If you require any form of help on a Ford truck, we'll be glad to help and a few members here are from OZ as well. In our words, we'll hook you up!!!
K
kevin
23074[/snapback]
i think that i have enough parts but u never know what i will brake in the future once the motor is balanced i should get a bit more grunt things will start to brake so i might b looking in the future .Once i get the axles in things will b safe for a while thanks for the help
K
kevin
23015[/snapback]
i just got my computer about two months ago still trying to work it out got computers at work but thats the arms parts program not much internet work takes a while to work out but getting better at it .Fixing the bronco is a lot easyer i'm going to try to put a picture of my bronco on here gose
wrachet
Kansas City Area
23084[/snapback]
You'll get the hang of it in no time! Hey great looking Bronco! Hopefully by time I get done fixing up my "old" one, it will look like that! Just picked another Bronco for parts.
Colleen
K
kevin
Colleen
23274[/snapback]
it took a quite a while to get it looking like that i hate to admite it but i had to comvert so parts out of other makes to get it finished the seats r out of a mitsubisi and alot of little parts come from the local wreckers.i have done afew other cars but they didn't turn out as good
how long have you been working on yours
Sandoval_broncosauria
