JBG J-shifter
lukeyboy60
Cottonport, La
Just recieved a new J-shift from Jeff's Bronco Graveyard and having a time installing it. Anyone have any experience with this shift. I installed the bracket with the stud at the top and the little arm was not touching the t-case arms. So I put the bracket the other way and now I can't get the shift on the bracket. Any suggestions? Has anyone had this problem? Do I need to put he bracket on the shift and then bolt the bracket to the mounts? Don't know if that is even possible. Thanks.
79' Buckin Bronco
