scroller bill
- Joined
- Aug 3, 2006
- Messages
- 61
- Reaction score
- 0
Hi all. As some of you know, I am in the process of restoring my 85 full size bronco to original.
Before I started it had headers, offenhauser intake, 4 brl carb and no emissions components. It ran good with this setup but unfortunately its not legal for the road. I got 95% of the original stuff from the junkyard. I installed the original exhaust and intake manifold and 1 brl carb. I put on a smog pump, diverter/bypass valve and hooked up all the vacuum lines. Hooked up the inline fuel filter. The engine cranked for awhile till the filter and carb filled up and then, THE BEAST CAME ALIVE AGAIN / . It smoked a little for awhile but I figure that was because I did not clean out the exhaust and intake manifold before installing it and it was probably just burning off any crap that may have been in there from the junkyard. It doesn't hesitate when I step on the throttle and comes back to idle with out a problem. And by the way, it's running on its own, I did not hook up anything to the computer yet. That will be the next step. It stoped smoking and runs just alittle ruff at idle so I need to do alittle fine tuning. It may idle better when the computer is hooked up.
I have a question. When I installed the smog pump I had to use the fan pulley that was being used by the a/c compressor(the a/c didn't work anyway). When I do decide to get the a/c working again, do I need to get a short belt so I can run the smog pump off of the alternator pulley? The alternator pulley is a double pulley.
Thanks. Bill
Thanks. Bill
