As requested by miesk5.
My 94 Bronco just stopped running, thank god it was in my driveway. Fuel pump not making a sound. Check all relays and fuses and they are good. I can jump out the contacts and the pump starts working. Have power to one side of the coil of the relay but it want work. Please help. Oh I have check the fuel shut off switch, not tripped.
I did pull and test all relays. They were good, but I will flip the horn relay with the fuel pump relay when I get home tonight anyway. Thanks again miesk5 for the info and I will let you know what happens. /emoticons/[email protected] 2x" width="20" height="20" />
1/3/11- I swaped the relays with no luck. All relays are good and I have hot "+" on one side of the coil, in the power box. No "-" I traced back threw all the tape to the EEC test plug. Good to there, then it goes to a block that connects threw firewall. WOW!!! Does anybody know where the - goes???
