Red95gotpotential
Red95GotPotential
I'm trying to put a shorter pipe in my intake. I have a cone filter on it but its using all the stock plumbing. I want to shorten the tube that runs from where the two pipes going to the throttle body connect into one, all the way to the filter. The problem I'm having is the small plug that goes before the mass flow sensor. What is that small plug? Do I need it? I unplugged it but the truck idles strange, but drives fine. The mass flow sensor will stretch as far as I want it to to add a shorter pipe, however that little plug does not. This is why i am trying to discard it. Thanks for any tips
/emoticons/[email protected] 2x" width="20" height="20" />
