Thanks. I'll try that firstDepends on which steering column you have, tilt or non-tilt. Also, the problem is not likely the ignition switch, it is more likely the metal dog that attaches it to the push rod. The rod is what actually operates the switch which is mounted on top of your steering column under the dash. You could temporarily remove the column shroud and operate the push rod by hand. Pushing all the way down puts it in the START position, letting go of it after the engine starts puts it in the RUN position and pulling it back from the RUN position will put you in OFF or ACCESSORY depending on how far back you pull the rod.
If the rod thing works then the problem is the gear on the end of the cylinder, upper rod actuator or the lower rod actuator.
Got access to the rod. Rod is moving all key selections. What I did notice was the key does not come back to the run position after turning key to the start position. Truck start by old fashion way, shorting out solenoid.Thanks. I'll try that first
Does the key move the rod? ie. when you turn the key, the rod should move with it. If you can manually push the rod to the START position and it doesn't return to the RUN position when you let go, then the switch that is mounted on the top of the steering column is bad. It should have a spring in it that pushes the rod back from the START position to the RUN position. The switch on top of the column looks like This http://www.lmctruck.com/icatalog/fd/full.aspx?Page=151 number 28 . While you are down there looking at the switch, make sure that it is properly secured, the bolts may have come loose causing it to shift out of position and not function properly.Got access to the rod. Rod is moving all key selections. What I did notice was the key does not come back to the run position after turning key to the start position. Truck start by old fashion way, shorting out solenoid.
